In Creo 3.0 if we give cosmetic thread in 3D model...that is shown as hidden line in 2D drawing... Can anyone suggest me is that correct ? if so can u please share the document on the same.
hsuryaprakash
Hi All, Please help me on this.
In BS8888 a female thread would be hidden detail but a male should be a solid line but thinner than your main drawing lines. You may need to look at the config options and your .dtl
Sir,
             can you give me more details about this and how to do that
mashton-2
(To:spandian)
If you go into "Tools" then "Options" you ca set your "config.pro" options.
For a full list of options google "creo config options" this should find a PDF "PTC Creo3.0 Configuration Options"
Here is a link to the list of .dtl settings http://www.beyondmech.com/pro-e/cad-topic-31.html
ASME Y14.6
