Increase Sketch Dimension Text Height
J.D.Mather
How can I change the sketch dimension text height while in the sketcher to help my poor eyes?
I project the program on a screen during lecture and it is difficult to see the numbers moving about the room.
Wildfire errr creo? v5
JD Mather
Certified SolidWorks Professional
Autodesk Inventor Certified Expert
11 REPLIES 11
You'll be wanting to set the hidden config option
Text_height_factor
Set it to 50 and work from there.
Regards
Iain
rhills
2-Explorer
(To:J.D.Mather)
To build on what Iain has said, I like ALL of my fonts to be slightly
larger. Here is a list of config options that I have documented for our
users if they would like to change the font type and sizes. The
TEXT_HEIGHT_FACTOR is the one that you want for sketcher. However, that
will also increase the font size inside your normal working windows,
too, not just the sketcher. The other options can be used to increase
the font size in the other menus.
1. MENU_FONT - If you would like to change the default font for
your menus, use the config option MENU_FONT. To set the value for the
option, enter the font name, style and size separated by commas. For
example: MENU_FONT Times, Bold, 24. It is not necessary to enter all
three values. If you would just enter Bold, Pro/E would keep the
standard font that it uses, but would make it bold. This option
requires a restart of Pro/E to take affect.
2. DEFAULT_FONT - To set the default font for the rest of the areas
that MENU_FONT misses, use DEFAULT_FONT. This will change the font of
the model tree, layer tree, message window, etc. Enter the same
information as the MENU_FONT config option. (See item #7) This option
3. POPUPHELP_FONT - To set the default font for the pop-up help
menus, use that POPUPHELP_FONT config option. The font values would be
entered the same as with the MENU_FONT config option. (See item #7)
This option requires a restart of Pro/E to take affect.
4. TEXT_HEIGHT_FACTOR - To change the font height of the characters
inside the working window, use the config option TEXT_HEIGHT_FACTOR.
The default is around 60. A value of 40 would make the text height
quite a bit larger. This value can be tweaked to your own preferences.
AWESOME!!!
Now I can see what I'm doing!
Scary!!
GE Healthcare Technologies
Clinical Systems
Monitoring Solutions
Eric R. Slotty
Mechanical Designer
8200 W. Tower Avenue
Milwaukee, WI 53223
...and if you really want to mess with someone, set MENU_FONT to use the wingdings font in windows. Much hilarity will ensue... It might be best to save this for April First.
-marc
This is going to be great information for classroom projection. (heck - I needed this for my desktop, let alone lab projection)
Took me a bit to figure out how to change it (see attached).
Need to start new part for sketch specific changes and restart program for program interface specific changes.
JD Mather
On a related note: Why isn't Lock User Defined Dimensions the default, and do you guys set this as your default for sketch dimensions?
JD Mather
Take a look at the config.pro options:
sketcher_dimension_autolock
sketcher_lock_modified_dims
> JD Mather
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
One of these days "someone" is going to come up with a plausible
explanation for "hidden config options"... Course, this is PTC, so
I'm not holding my breath... 😉
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
My guess is that those are for specific issues that are not ready for
prime time, or problematic only for a select configuration of hardware /
software / etc...
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
Folks -
This has been an issue with me for quite some time now: I have a part
that has been mirrored from the original part. The Original part has many
Copy geometry features at the beginning of the model tree and they are also
on a layer so I can shut them on and off upon preference, (which works like
it's supposed too). My situation is when the mirror part is created; all the
layers go with the mirror part. The layers are turned off, which does
work... but when I cruise my cursor over the model geometry while the layers
are turned off, all of the Copy geometry still highlights and creates a big
visual mess. All of the surfs (copy geom.) are on layers and they are turned
off but yet still highlight, everytime I cruise my cursor over the model.
This is very annoying to say the least. Does anybody in this group have any
recommendations that I can try to alleviate this? Thanks
Best regards
Kelly Gensley
Genz Design & Machine L.L.C
Victor, Iowa 52347
Ph: 319-444-0261
"Nothing of Value comes without being earned"-Anonymous-
CONFIDENTIALITY NOTICE. The information contained in this e-mail, and any
attachment therein, is CONFIDENTIAL and for use only by the addressee and
solely for authorized purposes. If you are not the intended recipient,
please return the e-mail to the sender and irreversibly delete it from your
computer. Unauthorized copying, distribution or dissemination of this email
or any attachments is prohibited and is the confidential property of the
sender. Sender does not guarantee that the email and attachments are
virus-free, and accepts no liability for any damage sustained as a result of
viruses.
Resolved . http://communities.ptc.com/thread/32023
In Reply to Kelly Gensley:
Folks -
Best regards
Kelly Gensley
Victor, Iowa 52347
Ph: 319-444-0261
viruses.
