Inquiry Regarding Flat Pattern Generation and Feature Suppression in Image ?
pobsd
Could someone please clarify why an additional line is appearing on the V-notch in Image 2? Additionally, what distinguishes the process of generating a flat pattern directly from the "customize graphics toolbar" compared to using the unbend features from the "Ribbon" and then creating the flat pattern from the family table after suppressing all features?
  1. In Image-1, I generated the flat pattern using the customize graphics toolbar.
  2. In Image-2, I utilized the bend feature from the toolbar and suppressed all features in the family table after all bends were made.
Image-1
Image-2
kdirth
(To:pobsd)
The unbend operation will allow you to unbend any or all bends in order to perform other operations such as create your own relief cuts then bend it back to continue.  The flat pattern feature always stays at the end of the model tree and flattens all bends and forms.
By suppressing the bend features, to get back to your original shape, the bent areas no longer exist in the model.
To remove the tangent lines in the drawing, use Edge Display to erase those lines.
8 REPLIES 8
StephenW
(To:pobsd)
I'll have to say I can't see anything. The image quality it really bad and I can't see any difference.
pobsd
(To:StephenW)
StephenW
(To:pobsd)
Those are tangent lines for the bend. I'm  assuming that's the bend centerline in the view.
The 2 ways to create the flat today are family table (Pro/e flat state) and the simplified rep flat which was introduced at some point, not sure when.
kdirth
(To:pobsd)
Are you modeling the flat shape then bending it, with image 1 being the original shape and image 2 being a generated flat pattern?  If this is the case, the added lines are tangent lines, as @StephenW pointed out., that define the bend area, created in the bend operation.
pobsd
(To:kdirth)
Thank you for the reply and looking on this .
Yes, I model the 3D sheet metal shape and bending it to create a flat pattern.
I see that tangent line when I create the flat pattern as DXF for programming for the bending one. Which I do not want to display in the programming? As I discovered later, the flat pattern generated from Flat pattern does not have that tangent line in the dxf. Just wondering why the same flat pattern comes in different forms?
kdirth
(To:pobsd)
pobsd
(To:kdirth)
Thank you @kdirth
pobsd
(To:StephenW)
I have just updated the two images with better quality. I appreciate you taking the time to look at this.
