Insert a note from file
Dale_Rosema
In WF5.0, I used to be able to insert a note from a file.
We recently moved to Creo 4.0 and I cannot find that command. Tried using the "magnifying glass" to search for it, but couldn't.
click Note button and select note location. You will see Format tab
Click Note from File button and select input file.
Martin Hanák
2 REPLIES 2
Martin Hanák
Dale_Rosema
(To:MartinHanak)
Thanks Martin!
One of those things you'd spend hours looking for.
