Inserting the parameters of the model into a drawing
mstary
7-Bedrock
Inserting the parameters of the model into a drawing can be faster, if I could choose from list. (Like the "Insert Field")
3 REPLIES 3
ChrisPLM
(To:mstary)
Hi Martin
similar to your previous idea. Why do you want to copy parameters from the model into the drawing file ?
Best regards
TomU
(To:mstary)
Chris,
Virtually every parameter on our drawing title block is actually a model parameter.  This allows us to display the value from the model and also directly edit it right from the drawing.  I think what Martin is looking for is an menu based method of creating these on the drawing (instead of &PARAM_NAME.)
By the way, the drawing file itself does contain all these same parameters (for Windchill's sake), but we use a drawing program to automatically keep them in sync with the model.  The model's values are the one we control and change.
BenLoosli
(To:mstary)
Like Tom said, the functionality is in Creo already. You just need to setup your drawing formats with the model parameter names so the system will transfer the values.
