hej i need some help with some Relations with parameters in an Assembly and parts from an interchange Assembly:
Situation is as follows:
I do have a Top Level Assembly, in this Top Level Assembly i have a Componet with Feat ID 123
This Component is in an Interchange Assembly defined with reference tags. each Componet from the Interchange Assembly has 3 parameters named A,B,C
how can i acces those Parameters cause i would like to use them in a relation.
i tried to call them with :FID or: CID
it works until i replace the part in the Top Assembly using the replace by interchange command.
when i do this the Feat ID will be changed from Feat ID 123 to Feat ID 124, with that my relation is not working any longer. because in my relation i use :CID i tried before using :FID but my parameters have different FID: Numbers so that doesn't work either.
hope someone can help me with this 🙂
Regards
Markus
Hello @MK_9183946 . If you want parameters to be called whenever you want them , use NOTEBOOK in creo to store parameters. They become global which can be accessed whenever needed.
Hello Lewis,
thanks for the hint, i never used Notebook as i am just starting with Creo, would work a Mathcad sheet the same way as the Notebook or is there still some difference in it?
else the problem is that i have several components from an interchange assembly that i want to swap, they have the same parameter names with different values, and i want to have that the different values in my assembly automatically just with replacing the component., as they are just three angles that different i created a measuremetn analysis in my assembly and the angles i used planes for to measure them and these have the same reference tags so it gets the job done, but looks like a messy workaround, pretty sure there is some smarter way in doing it.
Regards
Markus
