Is 2D analysis possible with ANSYS CREO?
  • September 14, 2022
  • 963 views
I fear that you are not in the correct community. Here you are in the community "Creo Elements Direct" that is a software different from Creo Parametric. You should move your post to the community "Creo Parametric" to have a better chance to get an answer.
Thankyou! I'll post in the parametric community.
