Is '-batch_mode' option available for asynchronous execution of Creo
  • July 7, 2016
  • 2301 views
I came across following article about command-line parameters that ProductView Adapters executes Pro/ENGINEER with,
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS79370
There is a mention about a new comman line argument '-batch_mode' which ProductView Adapters uses.
-batch_mode : Blocks all popups and prompts from Pro/ENGINEER to the user
I tried it with my program but could not see an effect of it. My dialogs (e.g. ProUIColorSelectionShow ) are not suppressed.
Does anyone have experience in using this parameter with an asynchronous Creo program ?
Is it mandatory to use 'parametric.bat' file to make it work ? Can't we use paramteric.exe as it is ?
Thanks !
S
Hi Swapnil -
Did you read the Creo Parametric Toolkit User Guide section named Core: Asynchronous Mode? This excerpt appears at the end of that section:
Setting Up a Non-Interactive Session
You can spawn a PTC Creo Parametric session that is both noninteractive and nongraphical. In asynchronous mode, include the following arguments in the call to ProEngineerStart():
• -g:no_graphics—Turn off the graphics display.
• -i:rpc_input—Cause PTC Creo Parametric to expect input from your asynchronous application only.
Both of these arguments are required, but the order is not important. The syntax of the call for a noninteractive, nongraphical session is as follows:
ProEngineerStart ("parametric -g:no_graphics -i:rpc_input", <text_dir>);
In the syntax, parametric is the command to start PTC Creo Parametric.
I hope this helps.
|+|  M a r k  |+|
Hi Mark,
Thanks !
I am already using '-g:no_graphics -i:rpc_input' options in my program.
IMHO no_graphics option just runs Creo in hidden mode, but it does not stop any pop-up dialog coming. ( So it is not a true batch mode)
For suppressing some dialogs, I use specific config options, but could not handle all dialogs popping up in the process.
My asynchronous batch program stops , in case any such dialog appears.
I came across link mentioned in my question and mention of -batch-mode option raised my curiosity.
Swapnil
