Is '-batch_mode' option available for asynchronous execution of Creo
I came across following article about command-line parameters that ProductView Adapters executes Pro/ENGINEER with,
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS79370
There is a mention about a new comman line argument '-batch_mode' which ProductView Adapters uses.
-batch_mode : Blocks all popups and prompts from Pro/ENGINEER to the user
I tried it with my program but could not see an effect of it. My dialogs (e.g. ProUIColorSelectionShow ) are not suppressed.
Does anyone have experience in using this parameter with an asynchronous Creo program ?
Is it mandatory to use 'parametric.bat' file to make it work ? Can't we use paramteric.exe as it is ?
Thanks !
S
