Hi..
Is it possible to copy data from excel to drawing table as below,
Prashant pandarkar
Save Excel table as CSV. Select Table From File, change Type to CSV and locate saved CSV.
Hi..
I want to copy only one column, because my half table is repeat region and half is editable.
so i want to copy only one column from excel to creo drawing.
.csv method already tried but we can not maintain repeat region in .csv method.
Prashant Pandarkar
I do not believe there is a way to combine tables. You will need to manually cut and paste text from excel into individual table cells.
split your table into two ones - 1st table containing repeat region, 2nd table containing editable information. Align table borders to simulate "one table".
MH
A repeat region is dynamically synchronized with the model data, but the spreadsheet information isn't.
It would be easier to add repeat region relations and a repeat region parameter instead of doing that work in Excel and trying to join the data later.
