Is it possible to download more Creo Drawing Templates?
jguevara
2-Explorer
Hello all! I've tried googling my solution but to my disdain nothing has appeared.
For some university projects I'm working on them at home on my Academic Creo version; however some of the projects call on using a that my version of creo does not have. Is there a place where I can download these templates?
Example: I need the a-h-3-views drawing template for a drawing of an assembly that I'm working on. Where could I find that particular template? Thank you!
StephenW
(To:jguevara)
Drawing templates are usually company or in your case university specific. It's possible your instructor has the template available for you.
5 REPLIES 5
do drawing template by yourself . I think this is the quickiest way how to finish your work.
MH
Martin Hanák
Hello jorge guevara
save a copy of desired format size and modify it als you wish. (As MartinHanak wrote.)
l think it´s it not possible to find 100% perfect format on the internet.
Just take some inspiration from internet and drawings of colaborating companies.
Regards
Milan
StephenW
(To:jguevara)
Think there is no better explanation than Stephen Williams ´s.
Think it should be marked as correct answer in order to help other users.
jguevara
2-Explorer
(To:StephenW)
Thanks Stephen. It turns out that the instructions had unwritten corrections to them; the template that we were supposed to use was a template we had already created earlier this semester. Thanks for your answer though!
