Is possible to modify name settings of shared parts?
Ed13
8-Gravel
When i make a multiple shared parts the program automaticaly gives the same name.different number of each part (the number is from .1 to .XX)   :
When in the structure browser the program put shared parts, the order is not correct because the order put first all the .1X parts second .2X parts etc.This is no logical order.
For me one way to do it right is give another range of names like (the number from .01 to .XX):
Is possible change some setting to do it autiomatically on Direct/Modeling V.17?
mmaenpaa
(To:Ed13)
I'm using V18.1, I would think this setting is available in V17 also,
In System Settings, go to Name Suffix >Minimum width of number suffix: and change it to 2.
Hope this helps!
MIke
mmaenpaa
(To:Ed13)
Hope this helps!
MIke
Ed13
8-Gravel
(To:mmaenpaa)
Yes, is available in V17.
Thank you.
