Is there a config option so the drawing views will automatically update when a model has been modified? Now we have to manually update the sheets so the views will update to the latest model changes.
auto_regen_views YES
Yes is default.
auto_regen_views is something little different.
ProE help says:
Yes - Automatically repaints the drawing display when changing from one window to another.
No - Update to drawing views will only occur when manual updates are made via Repaint or View> Update.
If you change dimmension in graphic area and swith to drawing, than it is what you are looking for.
If you are in drawing space, call some dimmension and change it, than you have to regen and repaint manualy. ---> l think there is no config.pro option for automatic repain after 1 dimmension was changed.
l think it is missing from the reason of CPU or graphics card computing capacity. But it is just my personal opinion...
I agree. There is no automatic regen of the drawing when changing from within the drawing.
Brad,
also set save_display config.pro option to no
See save_display for information.
Martin Hanak
