I am using Creo Parametric 7.0.
Background:
I am producing a mdl/dwg for manufacturing which uses the final machining mdl as a merged part. I am doing this to create a mdl/dwg template for automation which will be driven by the final machining mdl. Majority of the dimensions from the final machining mdl are needed for the manufacturing dwg.
Question:
Outside of manually recreating these dimensions in the manufacturing mdl, does anyone know if there is a way to display the dimensions from the merged final machining mdl in the manufacturing dwg?
Thank you!
The inheritance option when using merge will enable access to the dimensions from the source model in the derivative part (mfg model).
Solution:
Solution:
Dimensions from a merge cannot be displayed. If you toggle the merge to an inheritance, you can show dimensions.
This seems to be the solution! Thank you!
I will keep this open until I have tested our program and replacement / regeneration proves successful!
