Is there a way to change a parameter when a certain simplified rep is active?
joebot
I have a model that changes based upon a yes/no parameter.  I would like to change this yes/no value when I change to a certain simprep in a drawing.  Is there a relation function I could use to check which simplified rep is active?  maybe some other way of handling this?
Alternatively, is there a way to set a parameter for only a single view/sheet in a drawing?
TomU
(To:joebot)
Simplified reps will let you suppress and resume things, but to have parameters or dimensions change in different views you will have to use family tables and create separate instances.
