I am trying to erase offset lines from detailed view but i couldn't.. any comments on this??
Hi Dhanraj,
It is not possible to remove explode lines from a detailed view without removing them from parent view because they are inherited from the parent.
As a workaround, try creating the view as a general partial view or change the view type from detail to general and the offset lines in this new general partial view can be blanked via layers.
Hi Dhanraj,
They can be layered in the model so you can be selective if it is important enough. I have had to do this on all the lines before where I wanted them shown in one exploded view but not another whic were otherwise identical.
