Is there any option to erase offset lines from detailed view?
dm-4
7-Bedrock
I am trying to erase offset lines from detailed view but i couldn't.. any comments on this??
ClintWalton
(To:dm-4)
Hi Dhanraj,
It is not possible to remove explode lines from a detailed view without removing them from parent view because they are inherited from the parent.
As a workaround, try creating the view as a general partial view or change the view type from detail to general and the offset lines in this new general partial view can be blanked via layers.
ClintWalton
(To:dm-4)
Hi Dhanraj,
TomD.inPDX
(To:dm-4)
They can be layered in the model so you can be selective if it is important enough. I have had to do this on all the lines before where I wanted them shown in one exploded view but not another whic were otherwise identical.
