is there a way to make dreo not change axis id or surface id when you redefine a hole? I do not remember having this issue with Wildfire. What i have found is that if you move a hole it chages the axis id and my assembly falls apart. it does the same thing if you change the diameter of a hole.
Well, M030 didnt fix this. This is a very anoying problem. I just changed the depth of a counterbored hole and now all 45 bolts need redefined,
I wonder what may be wrong... I just moved a hole from one face to another and the axis remained A-3.
(Creo 2.0 M030)
if you notice the Dim in a different color are a result from a hole being altered, Either relocated or diameter changed. You have to go back and delete these dim and redo the drawing. In the model there is a flange inserted into the hole that has to also be redefined.
Thoughts?
I can not reproduce this problem. Certainly worth a customer service ticket, no doubt, but this might be a "way of working" issue.
I'm sure I will run into this at some point, so I appreciate your posting this.
Just to clarify, are thos assembly dimensions in the model, maybe in a distance contraint, or are they drawing dimensions? Are they tied to the hole's cylinder/edge or the axis?
