It does not stop when parts interfere with each other
ykimura
Hello everyone
We are arranging two parts in the assembly with "ball" constraint.
Each does not interfere, it is arranged with a gap of 0.5 mm.
If you execute "dragging component parts" in that state, parts will pass through without stopping at the time of interference.
Changing the gap of parts to 1.0 mm now stops at interference.
Is this a problem?
5 REPLIES 5
dschenken
(To:ykimura)
I would try changing the config option edge_display_quality  to high.
ykimura
(To:dschenken)
dschenken
Thank you for your quick reply
I tried changing the configuration setting, but unfortunately the phenomenon did not change.
dschenken
(To:ykimura)
Did you restart Creo after changing the config option? It should also be changeable in the View menus, but the config option sets it for all graphics and you may want to remove it for normal use.
My thinking is that Creo uses the tessellation of the model and detects interferences based on what is sent to the graphics card for dynamic dragging interference detection rather than a precise calculation.
ykimura
(To:dschenken)
Thank you
Yes. It restarts after config setting.
Where do you point to the view menu afterwards?
ykimura
(To:ykimura)
Thank you for your help.
After all, because I do not know the cause, I decided to contact PTC support.
Thank you very much.
