Hi all,
Alfonso, please take a look at 'Matrix Decomposition' chapter of 'Geometric Tools for Computer Graphics' book (http://www.amazon.com/Geometric-Computer-Graphics-Morgan-Kaufmann/dp/1558605940). Pro/E uses RzRxRy factor.
HIH.
Feliks.
In Reply to alfonso medina:
I'm trying to export a coordinate system from pro/e as a location (2,3,4)
and its axis rotations (90,34,15).
I kind of got something going. It looks like both the XAxis, Y&Z and the
matrix for a transform will give a rotation transform.
The thing is that, its not the same as the axis rotation angles shown in
pro/e when you go to the rotate coordinate datum section.
basically the default system is:
[100]
[010]
[001]
and if you rotate it say 90 degrees on the Z axis you get:
[010]
[-100]
[001]
So the positive X axis is where the positive Y axis used to be
I expect to use the cross product and the dot product in a atan2 function
to give me a signed angle, but look:
X and Y will be plus or minus 90 degrees while Z shows no rotation at all.
[001]->[001]
So eventually I came to the rodrigues formula for rotations :
http://en.wikipedia.org/wiki/Rodrigues'_rotation_formula
and I'm trying to figure out how I can get alpha, beta and gama from the
matrix. I "think " this is what I'm after. I think these are the angles
shown in the pro/e coordinate system window.
If you got an idea of what i'm talking about, I could use some help.
Rotations in matrix algebra are so neat and interesting for sure.
