JT client initialization failed
tlangner
2-Explorer
Hallo community,
when I try to save an assambly in Creo Parametric 4.0 as a JT-format
the following Error pops up:
Does anyone knows how to solve this problem?
3 REPLIES 3
were you able to save JT file in previous Creo versions (Creo 3.0, 2.0) ?
Does your license contains Interface for JT module (code 263) ?
Martin Hanák
Hey Martin,
yes, my license contains the JT module (code 263).
It's the first time trying to save an assambly as JT, so I never tried in Creo 3.0, 2.0.
Tim
the problem is related to Creo installation. During installation you have to click Customize button and select Creo Parametric Interface for JT.
jt_installation.pngWhen you do this, installer inserts JtToPro.exe into ...\Common Files\x86e_win64\obj directory.
Martin Hanák
