Hallo community,
when I try to save an assambly in Creo Parametric 4.0 as a JT-format
the following Error pops up:
Does anyone knows how to solve this problem?
were you able to save JT file in previous Creo versions (Creo 3.0, 2.0) ?
Does your license contains Interface for JT module (code 263) ?
Hey Martin,
yes, my license contains the JT module (code 263).
It's the first time trying to save an assambly as JT, so I never tried in Creo 3.0, 2.0.
Tim
the problem is related to Creo installation. During installation you have to click Customize button and select Creo Parametric Interface for JT.
When you do this, installer inserts JtToPro.exe into ...\Common Files\x86e_win64\obj directory.
