When using Creo 2.0 how do you keep part features hidden in the model tree after you have shut down Creo . When I open re-open file all of my previous hidden features are unhidden.
Thanks for your help !
You have to manually save the layer status. Switch to the layer tree, click the right mouse button and select Save.
Thanks !!
You're welcome ![]()
