Layou Tab Disappears after loading Sheet Metal module
mmaenpaa
Just started using Creo Elements Direct 18.1 this week. Was using CoCretea 2007 previously.
After loading the Sheet Metal module, the Layout tab disappears and I haven't figured out how to get it back without exiting and restaring the software.
Has this happened to anyone else?
I need the Layout tab to transfer to Direct Drafting, unless of course I just type the commands at command line.
Can anyone help to prevent the tab from disappearing or how to re-load it when it does?
Thanks!
Mike
mmaenpaa
(To:mmaenpaa)
To bring back the Layout Tab, you need to enter (show-layout) at the command line.
Mike
2 REPLIES 2
mmaenpaa
(To:mmaenpaa)
What I also don't understand, is why Layout doesn't show up in the list of All Tabs in the customize dialog.
(see attached images)
Mike
mmaenpaa
(To:mmaenpaa)
Mike
