maybe someone could help me with this. I want to do a Top-Down layoutsketch. I know I must create a Notebook, and then declare my variable. And here is my problem, since when I click "declare", appears a windoy that displays "Layout" and when I click this, happens nothing. And the next steps are missing me. I want this variable to appear in "parameters" from my model assembly, and also in the parameters from every of the parts from this assembly I have.
My first problem is to declare the variable 😮
Thank you very much!
Best Regards,
Edna
The layout is declared from the assembly or part. This adds the parameters on the layout to the assembly or part list of parameters.
witout using notebook? I must use the "notebook" option. How can I declare this layout at the assembly?
