Line stock user defined parameters not showing up
Matthijs1
7-Bedrock
I'm trying to setup the piping module for use in our company. In the line stock menu you can set user defined parameters but they don't show up anywhere. I need them to show up in the solid pipe parts.
I have tried with the following test parameters and values
PARAMETER                VALUE
MAKE_FROM               A1612309
TESTMAKE                  BB
TESTPAR                      12
I have tried recreating the pipe after changing the linestock parameters. I have saved the line stock every time.
Is there something I'm doing wrong here?
1 REPLY 1
Hi @Matthijs1
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
