You can go to the options and turn off the datums, points, csys, axis and save the config so every time you open creo, all the displays are "off" by default.
This display is a system setting, not just for a single assembly. They are either on or off.
The way you handle them in specific files is to set up layers, add the items you need to control and hide the layers that has the items you don't want to see.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
