I'm trying to setup the piping module for use in our company. In the line stock menu you can set user defined parameters but they don't show up anywhere. I need them to show up in the solid pipe parts.
I have tried with the following test parameters and values
PARAMETER VALUE
MAKE_FROM A1612309
TESTMAKE BB
TESTPAR 12
I have tried recreating the pipe after changing the linestock parameters. I have saved the line stock every time.
Is there something I'm doing wrong here?
Hi @Matthijs1
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
