How do I change the line style for a component in a drawing?
I know I can select Component Display but my choices are limited and i have to select all components in the view individually.
My preferred method is to change the line style in the Assembly or the Component level and have the drawing use the line style for the 3D model to display in the drawing.
I cannot find any information for this.
Does anyone have any ideas?
to select all assembly components easily you can use Search tool
MH
MH
You can be executed as shown in picture
