Local Milling
ObdulioCorado
2-Explorer
Local Milling
Has anybody had any issues with local milling?
I recently used it but half ways thru the sequence I got an error at the controll that the arc center was out of range. I made several changes to the parameters but got the same error.
Any replys will be appreciated.
Obdulio Corado
Have you tried to revise your post-processor settings for arcs?Maybe you should break them 90º/180º? Are they in any plane other than XY? Arc center is absolute or incremental?
My first bet is that you post need to be enhanced...
JM2C
Daniel Santos - Sr. NC Programmer / CAM Support
Liebherr Aerospace Brasil
