Looking for a way to place a table from a file on a layer.
spaggioli1
7-Bedrock
We are looking for a way to place a table from a file and it's contents on a layer at the time of placement.
Can this be done?
4 REPLIES 4
kdirth
(To:spaggioli1)
Add layer rule to look for a drawing table.
Kdirth,
Thank you for the response. We are able to do that however it adds all the tables to the layer and is not at the time of placement.
We have come up with a couple of mapkeys that might work for us.
Thank you again.
Hi @spaggioli1,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
I did not receive an acceptable solution to this issue. We are working with a mapkey that is a work around but is not all that helpful.
spaggioli1
