MULTIPLE LEADERS
machinist
MULTIPLE LEADERS
Trying to dimension simlier holes using multiple leaders. Can anyone tell me how to create multiple leaders, without inserting a note and removing the text.
2 REPLIES 2
One suggestion, create a text note and select multiple entities while holding the control key down, this will create multiple leaders to the entities selected. Edit the note text with the dimension symbol desired, example &D75. ProE radius and diameter shown or created dimensions can only be attached to the the feature entity they reference. The idea is wrapped up in the associative nature of the feature and dimension. The recommend method for notating repeated dimensions is to use "X" (2X, 3X, ...). With ProE ideally the features would be a pattern and the numeral in the "X" would be the pattern symbol (&P1) to maintain the associativity. Regards-
Another trick not using the note process is to dimension each hole separately. If they are a pattern, then you will have to use the note. If they are sketched cuts then dimension them in sketcher.
