Macro with parameter
romaning
2-Explorer
Hello
I would like to make macro with using a model parameter.
I need macro to save drawing to dxf format. The name of dxf file has to be same as name of model.
The name of model is one of parameter.
I don´t know how automaticly use this parameter to create macro.
(I don´t want to write the name of file after start the macro)
Thank you for the advice
Hi Romaning,
I don't know if your model and drawing have the same name. Probably yes...
I send you the mapkey 'qw' that opens the drawing with the same name of the current model.
James shared it with 'Ptc Community' some time ago.
I think you 'only' need to add the action, after opening the drawing, save a dxf...
