Magically disappearing Drawing Dims
pwyndham
We have a drawing that we are trying to revise. It was made in the past with a different version of Pro/E. Whenever you go to add a new reference dimension and middle click to place dim. The dimension shows up and then 1/2 a second later disappears. Undo says that you can undo the creation of a dimension, but nothing shows up on the screen. This seems to happen on all sheets even with newly placed views.
Is there a drawing option that does not allow new dimensions. There are original dims on the drawing. We were able to update the template to the new format. We can added Parameters and new views. We can edit the text and move old dims. "Show and Erase" dims stick.
Hi Paul,
I seem to recall that there is a config option that allows or disallows created dimensions to do with saving with the model. I had a look on our Configs and we have
create_drawing_dims_only YES
Maybe if you have this set to NO and the model is read only it could cause the problem.
Regards, Brent
2 REPLIES 2
Hi Paul,
Regards, Brent
I gave you the correct answer points since your response works for this drawing.
I still have some questions on it, but we can get going with the revision now. The part and drawing are in an Intralink 3.4 workspace, so they are not locked. If I create a new drawing the dims can be created without issue.
Thanks for the idea.
Paul
