Manual Entry Filed in a Repeat Region
lsrutkowski
The title pretty much says it all. I have been asked if I can add a "notes" field to our standard BOM table, which is currently an automated repeat region table. The notes would be unique to each drawing (possibly to each PAGE in a drawing), so I cannot simply add a parameter to the parts.
Using Pro|ENGINEER Wildfire 4.0 M190 and Intralink 3.4 M062 on Windows 7 Enterprise 64-bit.
-Lawrence Srutkowski
Here is a work instruction that I created several years ago that still works. My suggestion would be to create a parameter in the model specific for the “drawing note”, and then you can override it per drawing according to the instructions that are attached.
Please forgive the screen captures, this was done when we were still using UNIX.
-Nick
