Mass Properties Tied to Sub-Assembly
dwilliams
Hi Gurus,
I have an assembly where the mass properties appear to be associated a one of its Sub-Assemblies. Can anyone tell me how this Sub-Assembly is getting assigned as the model in the mass properties?
[cid:image001.png@01CDD2EE.CF999250][cid:image002.png@01CDD2EE.CF999250]
I appreciate your time,
Dax Williams
Engineering E-Tools Administrator
GE Healthcare OEC
Surgery
-<">mailto:->
When model (assembly or part) contains relation
mass=mp_mass(")
and when config.pro option mass_property_calculate is set to automatic, mass properties of sub-assembly and parts will get calculated and assigned each time the assembly gets regenerated.
In WF3 that actually ment that you need to regenerate the assembly at least twice and save it for the mass properties to get populated among the subassemblies and parts.
Hope this helps.
Jure
