Petter,
I've tried your suggestion for assigning mass to a parameter and using that in relations without success.
My model has standard inlbs units and I'd like to create a parameter that will report the weight in both pounds and grams. I have a WEIGHT parameter that is set via relation equal to pro_mp_mass.
I then created a GRAMS parameter and assigned it the unit 'g'. I selected Utilities > Unit Sensitive in the relations dialog. I then created the relation grams = pro_mp_mass in the post relations section of the relations editor.
However, my GRAMS parameter is reporting the same value as my WEIGHT parameter.
What am I doing wrong?
I'm using WF4, M080
Doug Schaefer
Hi Doug,
It may be that the Utiliies > Unit Sensitive option is notchecked in the Relations menu. That did the trick in my case.
I attached a sample model to this post (anda screenshot of the Relations setting). I am using WF4 M090 and I have the config setting mass_property_calculate = automatic.
I hope this helps!
/Petter
