Is there a good, need material library so i wasted lots of time for this...but cannot find a definitive source online
someone hand out .mtl files for me.. plz
i need material limits items ( yield stress, ultimate stress) .
or current source for downloading Creo Material files something good please link here!
have a good day
@material @library @.mtl
I am not sure what version you are on but starting with Creo 4 there are Grainte materials included in the default install. If you want something outside if that you might want to be more specific.
As an aside you are unlikely to get a companies complete mtl library. Lawsuits have been filed over material allowables and it is a legal balancing act handing out properties. Material properties change with environments too so one number is not always the right answer.
glad to answer Chris
I use Creo3.0 ~ 7.0, I already know Creo have default MTL files, but my customers want other material files
so I attempt to make MTL files, but the material item is too many...
I don't want all of your company's files Even the minimum item want
Someone upload Material.rar but I think that file is inaccurate.
Why not just take a look at one of the .mtl files, then build your own for any materials you don't already have? You should be able to get properties online for the conditions you're interested in, possibly from the supplier of the materials.
glad to answer
I already found material information in www.matweb.com
but they have too many items for one ingredient, so I don't know what to use
cause I need MTL files even the least information.
have a good day!
