Material and Tolerance Table
pdiletti-2
Using Creo2.
I have some questions regarding Tolerance Table.
I have different tolerance tables ( *.ttl) for different plastic materials.
I'm wondering if it's possible to link the material with the specific table;
after material choosing it's possible to have the correct tol table selected ?
Is it also possible to write a note in the drawing with thename of applied Tolerance table: is a system parameter available for tolerance table ?
Thank you in advance .
Pier
0 REPLIES 0
