Material file parameter
STEVEG
Wecreatedour own parameters from way back in 1998 when we first went to IntraLink. One ofthe parameters is called MATERIAL. Current material files now have a parameter called PTC_MATERIAL_NAME.
I am trying to set up a relation so that our custom parameter will use that material file parameter. However, I cannot get the relation to work.
MATERIAL=material_param("PTC_MATERIAL_NAME")
Using PTC_MATERIAL_DESCRIPTION works just fine. Butwhen I try the NAME it tells me Invalid data type combination at right side of expression. Has anyone else been able to get it to work?
Steve G
STEVEG
(To:STEVEG)
This is what worked.
MATERIAL=PTC_MATERIAL_NAME
Thank you Lance
Steve G
