Measure distance in X Y Z direction is not working
vdevan
I tried to measure the distance between 2 points in x y z direction ,
I think i have used the right option, but the option seems to be not working (please see attached image)
any suggestions.
Thanks in advance.
Ian_Cure
(To:vdevan)
See attached, firstly "click here to add item" button and then select If you're in a part use the parts csys (pick in model tree) If you're in an assembly then pick the top assembly csys
Ian C
4 REPLIES 4
Ian_Cure
(To:vdevan)
use a csys in the projection box and expand the results window
Ian C
vdevan
(To:Ian_Cure)
hey lan,
Thanks for your  reply.
i tried again, But , that csys option is not showing for me ..
please take a look at the previous image i shared....
Ian_Cure
(To:vdevan)
Ian C
vdevan
(To:Ian_Cure)
opps,
thanks for the reply,
just realized that i have to select from the model tree ..
Thanks for your help ..
i do not know why this simple option is made complicated..
I was a SW user .. so ..
