Generate Point and Axis from 3D-Location and Unit Vectors
Hi CREO geniuses,
I would like to constrain a part to an assembly as point-to-point and axis-to-axis (the other DOF/clocking is not important for the sake of this request). The point and axis are to be defined by a 3d parametric point file (.pts) which I've successfully been able to integrate using the "offset coordinate system" option of the point feature. I would like to create an axis or line from those points whose direction is defined by either unit vectors (x-y-z) or clocking angles.
Location Unit Vector
0.0249 0.525 0.0305 0 -1 0
0.0249 0.525 0.4515 0 -1 0
0.4571 0.525 0.4515 0 -1 0
0.4571 0.525 0.0305 0 -1 0
Does anyone know of a good way to do this? I have alot of these points (the above is just a sample), so looking for a nice clean way to handle it.
Thank you to everybody in advance! 🙂
