Mechanism design WF3
BertilRogmark
When I do a pin connection the system always measures angles in an counter clockwise direction.
Similarly, when I do a slider connection the positive direction seems always to be left to right.
Is this possible to modify?
1 REPLY 1
Bertil,
After selecting your constraints, you can flip them. This should change your direction. I no longer have WF3, but I tried it in WF5 and it worked there.
Hope this helps,
Tim
