Hello all,
I am trying to educate myself in the use of Pro/Mechanism. I have been through the available tutorials (piston/crankshaft, cam/wheel, camshaft/rods) and they have been helpful. However,I don't understand and cannot find anything explaining how to set up a check surface in the mechanism. For example, if I were to have a block on top of a plate with a planar connection, I would like the block to slide freely around the planar surface until it hitsothercomponents mounted on theplate. Can this be done? If so, any help would be appreciated.
I have attached a view with a simple illustration. In this attachment, I would like the puck to slide around in the slot, but be constrained by the slot walls and stop at the pin.
Hi Robert,
There are a couple of ways to do, this;
More details on the new things in Pro/ENGINEER Wildfire 5.0 can be found here:
I hope this helps!
/Petter
