Model Datum Feature Leader
ethridged60
7-Bedrock
When I show annotation for a view to display the MODEL DATUM in a view it appears, I can drag it up or down vertically in the view but, I cant shorten this ridiculously long leader.
I have had this issue on many drawings.
The datum is attached and along plane on the model.
Found out something today.
SHIFT --> PICK the datum and you can do anything with the leader or position of the datum feature in your views.
3 REPLIES 3
tbraxton
(To:ethridged60)
If you use these techniques are you able to manipulate the leader?
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/detail/Performing_Dragging_Oprs_on_Draft_Set_Datums.html
Involute Development, LLC
Consulting Engineers
remy
(To:ethridged60)
Does this happen with all drawing created from a common template? how about a drawing created with a shipped template?
