Model Datum Point Angle
fgallagher
Having trouble getting my Datum B to rotate to the same angle as the part it is attached to which is 58 degrees. Any suggestions on how to rotate this to match with the Geo Tolerance?
1 REPLY 1
Unless it responds to modifying it's attachment ... I don't recall a rule that says the datum reference symbol needs to be aligned with the surface, though I agree it would look better.
Mostly of concern, the 58degree angle isn't a good dimension to use as there is no 'horizontal' part of a part to determine what it is 58 degrees from.
