Does ModelCHECK skip over bulk item parts? I am finding that MC will count the bulk item parts but not actually perform any checks on them. Is this correct?
Patrick Williams Sr. Systems Engineer II Mechanical Engineering Solutions Missile Systems Raytheon Company
TU/M12/8 6221 S Palo Verde Rd Tucson, AZ 85706 USA www.raytheon.com
This message contains information that may be confidential and privileged. Unless you are the addressee (or authorized to receive mail for the addressee), you should not use, copy or disclose to anyone this message or any information contained in this message. If you have received this message in error, please so advise the sender by reply e-mail and delete this message. Thank you for your cooperation.
You are correct. ModelCHECK doesn't process bulk items (as this is not a part nor an assembly). The bulk item check is meant only to report the number of bulk items found in the assembly.
