ModelCHECK Bulk Items
pwilliams-3
Does ModelCHECK skip over bulk item parts? I am finding that MC will
count the bulk item parts but not actually perform any checks on them. Is
this correct?
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Patrick,
You are correct. ModelCHECK doesn't process bulk items (as this is not a part nor an assembly). The bulk item check is meant only to report the number of bulk items found in the assembly.
Rosemary
Dmi3U
(To:pwilliams-3)
This is another "should have" for MC. I need to add parameters to bulk items and they are different from regular start model parameters...
