I am attempting to setup ModelCHECK Metrics using a MS Access database. I have the software components installed and am to the point where I need to setup the XML file. My documentation says there is an access_new_admin.xml file available at the PTC ProjectLink. My PTC rep is unable to find this file. With the software there is a new_admin.xml file, but I believe this is setup for use with an Oracle database. Does anyone have or know where I can get the access_new_admin.xml file.
Thank you,
Joe,
I was able to find a copy of this file for you.
Rosemary
