ModelCHECK Save Behavior
pwilliams-3
Hi All,
I have ModelCHECK configured with the following options:
CHECK_ALL_MODELS YN N
SKIP_MODELS YN N
MC_ENABLE YNA Y
MODE_RUN YN Y Y N Y (save mode)
I open an assembly then I open a component part of that assembly. I
change the part and then close it's window. I save the assembly but
ModelCHECK never runs on the part that I changed. What did I do that was
wrong? Shouldn't ModelCHECK run on the part that was changed?
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
0 REPLIES 0
